best result when grouting
sasik
How do you get the best results when you grout floors or walls. I all ways find when the grout is dry off it shrinks a little bit. what is the best way to prevent that from happening?
Thanks sasik
sasik... either you need to log in or you need to activate your account... this is why you can only post in the guest forum..
I just checked your account settings and you need to activate your account via the email you got when you signed up..
Also i have just resent you some new activation codes..click the link back and this will activate your account on tilers forums..:thumbsup:
mix the groght to recomendations of the bag do not overwash first wash should be a slurry ment to blend the grought lines second wash with a damp sponge not wet clean sponge every pass pull in one dirrection non sanded grought let it almost set up before taking off excess.this will also prevent acrlic bleed sorry cant spell to save my life
