Guest viewing is limited
Discuss Best solution to sealing bath to wall junction in the Canada Tile Advice area at TilersForums.com.
jond500
Hi All,
I'm just in the process of refitting my bathroom and am getting close to the point of having to make a decision as to which solution to use for sealing the bath joint where it joins the wall.
At the moment the bath is temporarily fitted and can be removed quite easily if required to fit a sealing system. I am a way away from tiling the walls but really need to get the best solution to ensure the finished job is watertight and done properly. Once I start fitting the rest of the Hardibacker 500 removing the bath will be impossible.
I have spent weeks looking around at loads on the web and thought I would ask the experts that fit these things regularly and don't want problems :)
The one that I like personally is one that Graham sell which laminates to the edge of the bath and then onto the substrate and you then tile over but have no idea if it#s any good.
Many thanks in advance your your help and advice.
Cheers,
Jon.
Reply to Best solution to sealing bath to wall junction in the Canada Tile Advice area at TilersForums.com
I intend to tank plasterboard with mapei mapgum (or similar) and tape the joints as shown in...
10K
Sorry if this is the incorrect forum for this question. I've searched everywhere and can't find...
SJPurdy
I have some 100mm sq limestone tiles that are being fixed in my bathroom and need to seal them...
7K
Hi guys I am after a bit of advice. I have spent some time reading through posts but it all...
5K
K
Hi, I have just finished ceramic tiling bathroom, walls & built in bath with power shower over...
5K
Rich Midge
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
