Best Tile Cutter 2009?
Re: Best Tiler cutter
Getting my 1st tile cutter. Can anyone suggest which one to go for?
I was thinking about a Husqvarna TC 670 or a Rubi ts 50 plus
I was in the same situiation a few days ago - I needed a tile cutter for 10mm porcelain floor tiles. I scanned the forum on tile cutters - took the consensus and bought a Big Clinker
Result? Brilliant - easy to use, requires very little effort and good clean cuts.
Cheap crap good enough for domestic use.
Otherwise go for Monty or best of all - Sigma.
I dont think it is cheap!
5 years guarantee must be based on something credible.
Why do you dis like that did you even try them?
You sound like bad hater!:incazzato:
got to be the tx700 or 900. i have the 700 also ts 40 and 60.these days its all wet cutting. but on the odd job which i need a cutter its the tx700 that comes out, the 1000kg breaker is the mutts nuts!
Hello and welcome...
The rubi tx700n is perfect for what you need....I have one and swear by it..
RUBI TX-700-N
- Ideal for cutting: heavy duty porcelain
- Swiveling ruler makes diagonal cuts easy!
- Also suitable for cutting standard ceramic tiles
- Maximum cutting length: 28" (71cm)
- Will cut a 500 x 500 mm tile diagonally
- Cutting thickness: 1/4"-13/16" (6-20mm)
- Separator power: 2,204lb (1000kg)
- High performance moving breaking system
- Angular measuring system for 0-45° cutting
- Lateral stop for repetitive cuts - straight & 45°
- Direct vision of the scoring and cutting line
- Complete with shockproof case
- Includes 10mm & 18mm scoring wheels
- 5 year guarantee
Weight 22.2 kg
Click here for video of TX-N machine in action
TradeTiler.Ltd Rubi TX-N Manual Tile Cutters
:iagree: superb cutter!
honza1,
Dan,
honza1,
Dan,
