Discuss Best Tile cutter in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com.
Reply to Best Tile cutter in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com
The Importance of Not Buying Cheap Tiling Tools - Pro Tiling Tools The Importance of Not Buying Cheap Tiling Tools Tiling is a popular home improvement project that can add value and aesthetic...
  • Question
Hi all. Just wanting some advice and wondering what the pros in here are using nowadays for cutting large format porc? Ive been relatively lucky up until recently and been able to cut most of...
  • Question
Currently using TX700N but obviously now too small for the 1200x600mm I'm increasingly being tasked with by customers. Up to now, I've been cutting the 1200mm length with angle grinder/diamond...
  • Question
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
  • Question
