Discuss Best Tile Trim Cutters in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com.
Same for me. Its the new mitre box designed by Deano.hacksaw with new blade and genesis mitre block especially made for tile trim works perfect every time for me
I bought one for cutting metal trim but it just smashed them up?If you want perfect mitres, you will not beat one of these.
EVOLUTION FURY 3-b 210mm Mitre Saw 240v CHOP SAW CUTS METAL AND WOOD
Quansol mitre block, brilliant bit of kit, perfect mitres
View: https://m.youtube.com/watch?v=zC9pzcLqZKg
About £30 shop around tho
that's what I have, it worked well but seems to cut off line now. Maybe damaged it some way.Same for me. Its the new mitre box designed by Deano.
Don't buy one of those blade scissors for cutting plastic trim because they squash the trim and don't make the proper degree cuts. I only use mine for cutting the trim down to size before it goes into the mitre box.
I admit they do take a bit of getting used to, as I had the same issue when I first started using mine.I bought one for cutting metal trim but it just smashed them up?
I can only fine them @£47. That includes spare guides and a hacksaw. Not sure I need another hacksaw but it does look good.Quansol mitre block, brilliant bit of kit, perfect mitres
that's the type I have @Diggy bit mine started to cut good one way the totally skew the other, regardless of how tight I tried to get the bolts and changed blades. I used Stanley branded blades. It may be the blade that bends, hard to tell, I use Stanley branded blades, is there a better one?I got these in June , very happy with them , changeable blades and feel strong and sturdy. Think Dave sells them.
Pro Tiler Professional Trim Snips | ProTilerTools
Diggy
Reply to Best Tile Trim Cutters in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com
