Discuss best tubbed adhesive for floors!? in the UK Tiling Forum area at TilersForums.com.
Nicobond do one.
They even reckon it will stick to the dreaded anhydrite screeds:surprised:
Nicobond do one.
Yeah, i used it once.I'm sure I had a tub of that once it's so gritty, As you trowel on the wall half just rolls off, It stuck to every thing except where you wanted it to. It was KAK
spenny if your unsure about which of the many thousands of addy to use then stick to bal for now white star / green star on the walls and rapid set floor adhesieve(powder on conc floors) and two part fast flex on timber floors (overboard as necessary and any polimer mod adhesive for porc wall and floor you wont go far wrong but allways read manufacturers instructions
Cracking post smurf.....Gaz :yes:spenny if your unsure about which of the many thousands of addy to use then stick to bal for now white star / green star on the walls and rapid set floor adhesieve(powder on conc floors) and two part fast flex on timber floors (overboard as necessary and any polimer mod adhesive for porc wall and floor you wont go far wrong but allways read manufacturers instructions
and just dont knock to much at a time
speed will come with experiance
and dont forget to check weight and load bearing capabilities of wall surfaces for large format wall tiles as these may also require powdered addy
Reply to best tubbed adhesive for floors!? in the UK Tiling Forum area at TilersForums.com
