Blunt Tool
Sorry Marc that Bosch looks a good bit of kit but kinda lost! Is it self levelling and then telling you where the floor dips or rises and also telling you floor is off level and which direction?
Discuss Bosch floor laser GSL2 in the Tiling Tools area at TilersForums.com.
Yes, basically Ian the two lines are adjusted manually until they form a single line Justin front of the unit.Sorry Marc that Bosch looks a good bit of kit but kinda lost! Is it self levelling and then telling you where the floor dips or rises and also telling you floor is off level and which direction?
Ok got it, definitely a good bit of kit and here's me walking around with a straight edge, level and piece of chalk trying to avoid all the full glasses of water!Yes, basically Ian the two lines are adjusted manually until they form a single line Justin front of the unit.
Then using the remote you can scan the floor for a complete 360degrees if you wish. Wherever the single line separates, there is a rise or fall in your floor. You can mark it so accurately that you can trace the outline of the lump or divet in the floor.
So you can either grind out the lumps or latex out the divets. You can even latex as you scan the floor and watch the lines come together and form one in front of you as you latex. That's what the target is for, it indicates a rise or fall, depending where the lines intersect it.
Haha yeah you know mate.Ok got it, definitely a good bit of kit and here's me walking around with a straight edge, level and piece of chalk trying to avoid all the full glasses of water!
Yeah I think it states 20m can't remember, I'd have to look.On a serious side tho presume it's good for like 30ft or something?
Never get a straight edge that size in van! Will inform wifeYeah I think it states 20m can't remember, I'd have to look.
If you were closer you'd be welcome to borrow it.Never get a straight edge that size in van! Will inform wife
It has to be Ian, the client is super fussy.Bet it will be some floor when finished!
I only do things once mate,Sure you won't have a snag list!
Reply to Bosch floor laser GSL2 in the Tiling Tools area at TilersForums.com
