Discuss Brazilian slate 900x900! in the British & UK Tiling Forum area at TilersForums.com.
surflaur
Think i might be biting off more than i can chew with this one. I've got a customer next week who want brazilian slate laying differing sizes of 400x400 600x600 and a couple of 900x900! Ive done quite a bit of slate so i know what it's like but not this big! I told the customer because it is uncalibrated there will be a variation in height and i will do my best to get them level. Problem is i can't see me laying a 900x900 tile onto adhesive and lifting it again to apply more or less adhesive, surely the suction alone will break my back?:mad2:
Please let me know if you have layed tiles this large and how to go about it. Also would i be better off with a grinder rather than the wet cutter?
sWe
If you haven't got a large enough wet cutter, you deffo need an angle grinder, but a large bridge wet saw is what I'd recommend.
Those 900x900 are bound to weigh atleast 20kg. If I were you, I'd use a mid bed, or a thick bed trowel. That way, you wouldn't have to lift them every time to adjust the levels; you'd just tap them down a bit more with a rubber mallet. Just don't tap too hard, or the purpose of the thicker adhesive bed is defeated. Also, make sure to immediatly remove excess addy from the grout lines.
Reply to Brazilian slate 900x900! in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
I hope you guys can help me. IN my own home, I have screeded in a front path slab because the...
Hi all, new to the forum, I'm a customer of a bodged tiling job done 2 years ago by a general...
    • Agree
I recently had my whole ground floor tiled as part of a larger renovation project. On moving...
14K
Q
    • Winner
    • Informative
So I was recently asked to fit some 3m x 1.5m 6mm thin porcelain in a new tile showroom. Mapei &...
8K
Qwerty
Q
    Votes: 9 5.3%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.7%
    Votes: 21 12.3%
    Votes: 40 23.4%
    Votes: 4 2.3%
    Votes: 4 2.3%
    Votes: 24 14.0%
    Votes: 19 11.1%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
