Builders at it again!
John Benton
5 years in to this bathroom and I don't for 1 minute believe it wasn't leaking from day 1.
Stud wall was rotten from floor to 3 ft high
Shower wall was 12mm ply
Tiles in niches fixed directly onto studwork
Tiles dot n dabbed directly onto chipboard floor
Porcelain tiles 60x30 fixed on all walls with tubbed addy
Not sure how it didn't collapse
I removed the stud wall (gloves and mask used) and flooring where rotten
Removed tiles on long shower wall to shoulder height
Built new stud wall and created new niche
Tanked all wet area
Tiled walls and grouted
Fixed Sandimat (1mm decoupling mat) had to use that so floor tiles would not be lipped
Grouted floor and siliconed
1.jpg 2.jpg 3.jpg 4.jpg 5.jpg 6.jpg 7.jpg 8.jpg 9.jpg 10.jpg 11.jpg 12.jpg 13.jpg 14.jpg 15.jpg 16.jpg
It was actually a pleasure to do (almost)
From a distance it didn't look too bad (3 miles in thick fog) but on closer inspection you could see where they had failed, in every department
The customer is away on holiday, I finished it today and they come back tomorrow so they haven't seen the mess when it all came apart, hence all the photos
PS the first pic is how it looked prior to removal haha
Haha it's ok John I could tell! Haha
Even showed the wife the end result, and I don't do that often as I'm sure u know why! haha but I can get away with the odd few!
It does look Kool, lovely and crisp!
Sort of stuff I love!
Absolutely hate doing jobs when the customer goes away on holiday,don't like one bit.
And whats wrong with grout ??? Id of cut the old grout out, sprayed some expanding foam in, let it set (thats the secret) then just grouted it back up,been fine for ages :kissingheart::kissing:
That's exactly what I thought and then read something about Dom being in the area soooooo..... 🙄
@John Benton i hope you don´t mind i share this in your thread, but since it´s related i thought it would be the right place instead of opening another thread.
This is a job that i did this year, it was a balcony in the attic of a house. The room right bellow the balcony had an infiltration and some of the mosaics on the balcony were starting to peel off.
Because the whole house as the same mosaics on the floor, the client wanted to stay the same.(It´s a discontinued mosaic) So i had to take all the mosaics and clean the adhesive behind . The funny thing is that the they did the waterproofing with fiberglass... the same that boats are build!(this helped me to take off almost the entire mosaics) First time i saw that !
After cleaning the mosaics and the floor i did the waterproofing with sikagard-570w (4 crossed coats) and then applied the mosaics with cross adhesive on the piece and the floor.
Because the client had saved 6 or 7 mosaics, i was able to do the job.0.jpg 1.jpg 2.jpg 3.jpg 4.jpg 5.jpg 6.jpg 7.jpg 8.jpg
John Benton,
Nuno,
John Benton,
Nuno,
