Discuss building a wooden fence in the British & UK Tiling Forum area at TilersForums.com.
charlie1
Alright guys, any advice on building a wooden fence (4ft ish) , my plan: dig holes for pre treated posts (every 2 meters) then plant posts in cement ( about a foot) make sure they are all plumb, then screw in the horizontal bits then the slats. Any further advice would be great if any of you guys have done this before.
tfs
1800mm centres for posts rails as timber merchants are generally 3600mm. Plant the posts to 600mm depth. I would use 4x4 posts. I did the holes to the depth of 600mm with a width of around 300 for a good solid fence. You can use post mix to speed uop the process and it generally works fine for this type of fence when the holes are not too wide.
Cut a slope on the top of the fence posts to let water fall away (treat with a trade sealer)
If you realy want to go the distance run you rails through a table saw (or use circular saw) to create an angle/fall on them too to prevent water sitting on them.
Use anular ring shank nails to prevent them going loose with weather change or use screws but you will be there all day though unless you have a colated gun. This is where as paslode does its magic.
charlie1
Have i missed something? What sort of fence are you building? Feather-edge board, panels, picket, slat, etc?
Just a pretty fence to keep the dogs out or dugs as they are generally known up here and keep the weaned in! And it needs to look pretty so I think a picket fence! So posts submerged 600 and 1.5m appart!
Tts, I like your tips on the sloping to preserve the wood! I was planning on just screwing it all together but might get my bro to get me a passlode. What's the best way of digging the holes? And I am aware of the spade, just wondering if there wad a fancy gadget I could hire?
Reply to building a wooden fence in the British & UK Tiling Forum area at TilersForums.com
11K
Rizzle from the Portizzle
We are looking to replace our floorboards (very bendy and have lots of holes) for either 22mm...
TJ Smiler
Hi Apologies for what i'm sure is a pretty obvious question: I'm about to do my second ever...
6K
Simon benn Leeds
Hi All, My first post here, I would say I am a decent enough DIY'er and have begun the...
matomato
Hi all, I am having my kitchen redone and will be installing Gris slate from either blue sky...
One Day
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
