By Eye
  • Thread starter Thread starter Perry
  • Start date Start date
  • Tags Tags
    usa
Ah! geometry! Takes me back to school in the early 70s.:grin:
Grumpy
Hi Grumpy its the way i do it on floors as they tend to be large areas where it is 4.5 mts 6.mts 7.5 mts the bigger the better Robs idea is something i used to use on smaller floors when i first started can be easer to do on your own 😛ete
The old 3 4 5 method is used in most trades, Joinery, Floor laying, tiling anyhting that requires setting out I guess. e.g. stud wall etc.
My tutor always advised that for larger areas we work to grids, we find our centres etc. and then start marking out grids of four by four tiles. I think this just takes ages though and would be of most benefit for use with design work.
I preffer to work from my centre with two battens screwed or nailed to the floor and check square via 3,4,5.
I prefer to work from my centre with two battens screwed or nailed to the floor and check square via 3,4,5.
tfs yep your tutor was right mate i grid floors to, except on 600x600 rectified with 2mm joints where it doesn't work has to be done with spacers model making matches in my case😛ete
levels/sqaures/tape/chalklines/pencils and the old 3.4.5 which ever is easiest method for the job in hand.....
Grumpy you need to be like Dave uses everything all at once :lol: or depends what he has in his hand at the time :joker:
