Discuss cable clips for UFH? in the UK Tiling Forum area at TilersForums.com.
doug boardley
Anybody ever used cable clips for fastening down UFH. I was just thinking that it'd be handy to use them to stop the bits that float up when you're covering with slc. Does anyone know of any reason why not to use them? I just think it would be a lot easier and cheaper than sticking the floaters down with rapid set.
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Providing they wont melt over time etc I'm sure you'd be fine. I saw some rail thing trailed once but never saw it on the market. The rail was fitted every couple of FT across the whole width of the floor and had hook things you hooked the cable onto at either end of the room and then hooked every couple of FT. You used loose cable for it and the cable still floated between the hook things to be honest.
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
If you had grooves in insulation you'd not be dispersing the heat. What you could do with is a cement layer on top of the insulation that's thick enough with a groove in it. Then the heat would disperse through the cement layer but the insulation would still do its job.
I routered grooves in plasterboard once and used that to feed the UFH cable into. Worked but wasn't fun (very messy) and I'm sure the performance could have been better.
Reply to cable clips for UFH? in the UK Tiling Forum area at TilersForums.com
Hi everyone, good to be here. I'm a DIYer putting down a loose UFH cable in my kitchen. I've...
hi, i am a virtually retired tiler (58), legs back hips etc etc. a friend carpenter (65) has...
Hi all, I'm new to the forum but have read many posts over the past year as I have created and...
6K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
