Discuss cable clips for UFH? in the British & UK Tiling Forum area at TilersForums.com.
If you had grooves in insulation you'd not be dispersing the heat. What you could do with is a cement layer on top of the insulation that's thick enough with a groove in it. Then the heat would disperse through the cement layer but the insulation would still do its job.
I routered grooves in plasterboard once and used that to feed the UFH cable into. Worked but wasn't fun (very messy) and I'm sure the performance could have been better.
If the clips is over the top of the wire then the slc or addy cant get to it so yes it will cause a hotspot
I wonder if the thin horseshoe ones used by BT would be any good?
This is what I use....... It's a large adjustable staple gun for cables. I've been using one for ten years without any problems. I use "Heat mat" mats and they have no problem with this method of fixing as long as the cables not compressed.
Reply to cable clips for UFH? in the British & UK Tiling Forum area at TilersForums.com
