chris.s
Hello. I was after a bit of advice from the people in the know.
I am planning to re-tile my quadrant shower enclosure but am slightly concerned that when I remove the old tile I am likely to remove a fair bit of plaster/render as well.
I am planning on tanking the enclosure with a mapei kit before installing mosaic tiles. I would like to get the bulk of the work done over one weekend if possible.
What I would like some advice on is what type of filler would be safe to use? The tanking kit says that you should leave the following minimum drying times;
Gypsum plaster-4 weeks (one week for skim coat),
Cement/sand render-2 weeks
Concrete-6 weeks
I have heard that you can use rapid set tile adhesive to fill deep holes by building up several layers, is this true and if so would it make a suitable base for the liquid membrane, once it has been primed?
I do not actually know the depth or extent of any holes as I've not taken the tiles off yet.
I have solid brick walls, not plasterboard.
Any tips, tricks or advice would be greatly appreciated,
Thanks in advance.
Concrete-6 weeks
Thanks in advance.
