Discuss can feel an arguement coming in the British & UK Tiling Forum area at TilersForums.com.
grahamster
hi guys, need to get armed with ammunition,just priced a kitchen floor,30m2.Told the customer to use 12mm ply blah blah,customer phoned joiner who in turn said 6mm ply will do,which i dont think is right,i know 6mm backer board is ok,but 12mm ply is the cheaper option,can you please give me some advice/ info so i can reply........cheers Graham.
grumpygrouter
Why don't you ask the joiner to give you some info on what adhesive and grout you should be using too, maybe even recommned the tiles and what size groutline is appropriate. He seems to know what's required, better still do as Dave says, get him on here and we can "point him in the right direction".
Stand you ground Graham, you are correct! 6mm ply? you might as well put lino down!
Grumpy
Thanks dave,but what im wanting to know is why not 6mm ply,i remember coming away from course last year,drummed into me that it was 12mm,& i have been quite lucky on the floors i have done that i have persuaded customer to use 6mm backer board,but i cant remeber why we dont use 6mm ply.......cheers Graham
6mm ply isn't rigid enough to stabilise the floor. It is too easy to screw it down and leave voids underneath.
grumpy
DHTiling
6mm ply and 6mm backerboard...totaly different materials mate....the 6mm ply isn't stable enough to strengthen the floor..and the 6mm backerboards are stuck down with adhesive and then screwed as well.... much stronger than 6mm ply alone....12mm ply will be cheaper option...make sure the orignal substrate is well fixed as well.....
Woody123
i agree with all of the comments mate. I would only use 12mm (min) ply with 2 part flexi adhesive. British Standards is 18mm ply but most think this is overkill. 6mm ply is just not structually stable. You could tell the customer that if you used 6mm ply the floor will flex as it wont have enough stability in it resulting in tiles possibly coming loose and grout cracking. If the customer still insists on this then i would either walk away or tell them that you will not guarentee any of your work against failure as correct procedures haven't been followed! Hope this helps
Chris
F
Fekin
I think it's a case of certain methods should be followed like not using just 6mm ply, but there will always be pleanty of people who use 6mm and don't have problems with it.
There again there will also be many that do have problems.
I guess it comes down to the customer too.
If they have had the floor done with 6mm, and 3 or 4 years down the line tiles start cracking or lifting, the customer might think well it might be time to have it done again, and not try and find the tiler who did it 3 or 4 years ago, where as someone using stronger or thicker boards might never fail or 10 years down the line.
Just like we have with PVA.
dptiling
clacton
to be honest i have only plyed small bathroom floors before and ive used 6mm plywood before ive not had any trouble with it
same here small areas, but tons of screws.
only because of height . with 12 mm
but have made a fuss of it .no movement before tiling.
never had any probs.
(when you think they addvertise addhesive to go stright on to tounge and grove floor boards) with no ply at all ...
Raja
Who's the tiler here...?....tell the joiner to stick to what he knows and leave the tiling to you........just tell the customer its 12mm or nothing..get someone else....or tell them to come on here and we will tell them what is required...........:thumbsup:
well said Dave like it when u go all masculine lol
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
British Standard says it's 18mm ply, not just 12. It's just 12 is used as a comprimise to 6 and 18. Though it's a risk at the tilers cost in some cases - though a good adhesive manufacturer should back you up a little if things do go wrong in the future.
H
howard
Ive started a job this week where the builder has put 6mm ply on the bathroom floor ive told the customer twice it should be 12mm and i could not not give a guarantee if we do not use the 12mm she spoke to the builder and he said he would guarantee the tiles will be ok so thats good enough for her so the 6mm is staying down :mad2:
Reply to can feel an arguement coming in the British & UK Tiling Forum area at TilersForums.com
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
Any body fixed tiles over this...Got the spec sheet In front of me and a bit nervous of tiling...
9K
Spare Tool
I'm almost lost for words!!!!! Last weekend I went to see a potential customer about some...
White Room
I had a job booked to retile 19m of kitchen floor where the house had apperently had a little...
wayfoward
Hi all, I am after a bit of advice after becoming conbfised over many different answers from...
7K
lizzardtong
L
    Votes: 9 5.3%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 48 28.4%
    Votes: 21 12.4%
    Votes: 40 23.7%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.6%
    Votes: 19 11.2%
    Votes: 17 10.1%
    Votes: 8 4.7%
    Votes: 5 3.0%
