Can Solar panels cause tripping when isolated Electrical Advice
Can Solar panels cause tripping when isolated Discussion ThreadCan Solar panels cause tripping when isolated Electrical Advice
Anyone know if its possible for a rooftop solar array to cause an RCD trip even when the solar circuit is isolated at its rotary isolator ? I've had no dealings with solar atall so wouldn't know . The solar circuit is in a split load RCD board. I'm assuming the solar install was bonafide as its on a fairly newbuild. Stray earth current leakage from the panel/inverter perhaps ??? is this a known issue with solar ?
Can Solar panels cause tripping when isolated for the original thread on Electricians Forums
