Can someone help before i lose hundreds
Hi all and thanks to all that replyed i will let u know how i get on with it
Once again Many thanks
Mike
Can I butt in and ask, what is the reason for not using flexible grout on every piece of work ?
Surely that would be overkill and avoid cracking ?
Flexi grouts more expensive and if your tiling ceramics then floors are the main time you need flexi grouts, but a bog standard ceramic wall tile for a full bathroom then normal grouts the way "microban" as a wall tile isn't subject to the stresses and strains a floor tile is asked to cope with.
Obviously if your tiling walls with Porcelain then flexi grouts the way then.
I was wondering about the 15mm ply too Gaz :huh2:
Hi mate,
You mentioend that you recently started up. Did you inform the customer of this or that you were not a tiler by trade?
Rather than walk away or pay for someone else to do the job, I think that it is reasonable to alow someone to try and correct there work if anything should ever go wrong (unless doing so would make matters worse)
You could perhaps tell the customer that you will regrout or whatever you feel would rectify the problem and would not consider getting in someone else unless you had at least had the chance to correct the work yourself.
A tip is to inform the customer that you are new to the trade, et them know that you may be a bit slower than ana experienced tiler. You should reassure them that you can do the work to a good standard(if this is true) and even offer your services at a cost lower than experienced tilers untill you become more knowledgable and experienced.
AN ABSOLUATE MUST! = Do your research before starting any job, read around the forum and ask questions if unsure. You should have all angles covered sub floor prep, correct materials etc, etc, etc.
This bad experience is down to lack of knowledge and experience in the trade and I am sure you will learn from this. I have been on a few job were I have underestimated the scale of the work involved and it is depressing when you miscalculate or overlook what seem to be minor details. The best thing to do is 'bite the bullet' get on with it and learn from your experiences.
good luck with the customer mate, dont let it get you down, instead use this to motivate yourself and learn more about the trade to better yourself and be the best you can be.
kris
Looks like i'm gonna need a soliciter guys, as they wont even reply to my calls.
Oh i did have a text from them saying the grouts not the problem.
the problem lies with the batons the ply is on.
They say they must be moving.
I put the floor down and as far as i'm concerned everything is tight.
Thanks for that kris
They were aware that i'm not a tiler by trade
Thanks to all
Mike
Hi all a short message before i put the kids to bed, i'll be back later.
and no i did'nt tell them, it's something they assumed, as the husband was supposedly in the building trade
mike
Buy a grout rake. Rake out the joints and regrout using a flexible grout or ordinary grout with an improver in it. Eat aload of humble pie and give a discount and then do the job properly in future. I dont know why I'm giving advice to someone who has just come into the trade and is now taking work away from experienced tilers like me but Im a christian and dont like unhappy endings. In future supply your own adhesive and grout cos when you get a good relationship with a supplier you will buy much cheaper than your customers will amd will therefore make a bigger profit.
Simon Lancaster
Hi Simon,
Thanks for the advice, was you not a newbie at some point.
did you not turn to someone for advice while you were starting.
Thats what this site is about, advice and exchanging ideas and tips.
I'm most put out by your comments of taking work away from you.
Mike
mikephillips,
tfs,
mikephillips,
tfs,
