Can you tell where I cheated?
It involved a wet cutter on a whole row!
Must have been in a dream world when I set out, it is 2440mm high and the tiles are 297mm.I marked up a stick to check the room, knowing I worked out for a cut tile at ceiling and floor level.
but.
didnt check the top of the window! When I got to this I was 20mm to high. Didnt fancy a 20mm cut over the window so I cut the second row down to suit the window top. 20mm of the whole row.
Pwhat a plonker! Don't think you can tell?:sofahide:
I did the exact same thing last week! Although mine was about 40mm too high!?! No idea what I was thinking!?! Luckily I started on the window wall, so found out fairly quickly.. Had to pull the lot off the wall, and start again. Doh!
I can't stand tiling around windows so i normally start on them to get them out the way............ Have also done what you did a couple of times mate, i was able to smash away enough of the reveal in my case though.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
