Discuss Ceramic Floor Tiles in the Best Floor Tiles area at TilersForums.com.
Derwent999
Hi,
Began striping old vinyl flooring Tiles to the concrete and found layer of the old black tar like adhesive, Maybe (Bitumen) still a bit tacky to touch.
Do you no of an adhesive to do the job-Ceramic Floor Tiles.
Can this adhesive be used to Tile over the Vinyl tiles without having to strip them down to concrete.
Can I use this adhesive over the black like previouse adhesive,Maybe Bitumen,(will not scrape off), to apply the floor tiles.
Can you help in any way, than you.
The Legend; Phil Hobson RIP
Hi and:welcome: the bitumen adhesive you descibe sounds to me like the stuff used to fix thermoplastic tiles, as the name implies they used to heat the tiles prior to fixing. ATA ()(apshalt tile adesive)can be removed by heat gun and scraper,messy job, and will leave residue.You might be as well contacting technical dept. of mapei,or like, if vinyl floor is sound, there are primers and adhesives that will do the job. Good luck.
Reply to Ceramic Floor Tiles in the Best Floor Tiles area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Ceramic Floor Tiles
Best Floor Tiles
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
