Ceramic tiles in a shower
Ceramics soak up water on the back of the tile.
So unless you don't read the instructions and fix them glazed side down then I don't see a problem ....🙂
What would your concerns be Andy?
My point being Andy , we tank walls because water gets past the tiles to the wall, which means, it will also get to the back of the tile and soak into a ceramic tile
Yes. If grouting is decent and fixing methods are decent then it will last twenty years under normal domestic use, two or three times a day.
Showers that are in use more, or loads more, need additional considerations. Ie tile choice, substrate choice, grout choice.
You put up cheap ceramics with tubbed adhesive onto bare plasterboard, then use the shower 20 times a day, it won't last.
Twice a day, good chance it will.
Tilers been fitting ceramics for years in showers ,ive done probably 500 like most guys on here never had one problem ,everything is porcelain now ,did my first cramics for a year last week ,got 12 houses to do
I did loads of units in a retirement home a couple of years back some with two bathrooms . All in ceramics with ready mix
Tanking and Wetrooms
Flintstone,
Qwerty,
Flintstone,
Qwerty,
