Seems like everyone has there own method for this job :smilewinkgrin:
I ended up giving Mapie a call and they advice I remove as much paint as I can then Prime with There primer G before applying there Ultraplan restoration screed Self leveling compound,
So I've purchased the above with a angle grinder for the paint,
Removing the paint is going to be a ***** but I'll give it a go:mad2:
Now that's interesting. That is EXACTLY what I suggested to someone about a week ago, except sand with a rotary floor machine instead of an angle grinder, to remove and loose or flaking paint, prime with Uzin acrylic primer then trowel on a thin coat of smoothing compound, leave 2 hours then begin tiling. And I got no end of abuse and nonsense from people who have never done anything other than spend 'n' hours filling the house with (probably toxic) dust by trying to get all the paint off with an angle grinder! And despite the fact I've beend doing exactly that for 18 years and never had an installation failure, or a problem.
Seems the Tech Dept at Mapei also know what they're talking about...
Before you spend money on an angle grinder (sounds like you don't own one), see if you can hire a rotary floor machine. If you can, it will be a hundred times faster to sand the paint down to an acceptable level. Et voila, even in England, rotary floor sanders exist.
HSS Hire - Commercial Floor Finishing Sander Hire and Rent Seems a bit of a lightweight one, stick a bag of self levelling compound on top of it while you're sanding to give it extra weight, and use the coarsest sand paper they have (24 grit, or even 16 if they have it).
That's what I'd do. A lot less dust and crap all over the house, and you'll sand it within 45 minutes. Once you've put your Mapei SLC on and it has dried, wizz over it with the sander again (10 minutes) and you're ready to tile.
