Discuss chip board floor in the British & UK Tiling Forum area at TilersForums.com.
Raja
Hello Burncross Hardi Backer is available only from Topps in sheffield ie shoreham st one or meadowhall one.
The last time i got it with trade discount going back a few months now was £9.70.for the 6mm board 1200x 1200 i think and the
12mm one which u need was £10.38 again 1200x1200
Not the cheapest to use but for a small area like that very good.
Easy to install and cuts bit like plasterboard i got a hardi backer knife only £6 also was from topps all the best.
Easier to go into Arnold Levers and get 12mm ply alot cheaper
ONLY tip do not buy thier screws as they r a rip off
All the best Raja
Raja
personally i would ply it out with 12mm ply screwed in a grid type fashion at 300mm intervals ,then prime ply before tiling......use 1 inch screws this should avoid any leaks.
To be honest Brian i would as well but incases where it is a small bathroom or if the customer wishes to spend the money on fine materials i would use hardi backer
BUT
If the customer just wanted the tiles down and cheapest quote would use ply as it is just as good if layed properly.
Only thing i like about Hardi Backer is very very easy to cut and hardly makes much difference in price if a job is upto say 5sq mtres.
chris.tiling
Poole
What is the consensus when using hardibacker / ply etc - and the customer says the floor height will be raised too much between room and whatever the door opens too? Plus who cuts the door down? I have done it once for an elderly couple, but wouldnt want to do it everytime
Reply to chip board floor in the British & UK Tiling Forum area at TilersForums.com
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
    • Friendly
chip board floor
    Votes: 9 5.3%
    Votes: 17 10.0%
    Votes: 12 7.1%
    Votes: 49 28.8%
    Votes: 21 12.4%
    Votes: 40 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.5%
    Votes: 19 11.2%
    Votes: 17 10.0%
    Votes: 8 4.7%
    Votes: 5 2.9%
