Guest viewing is limited
Discuss Chipboard, 6mm Hardie & Bal single part fastflex in the UK Tiling Forum area at TilersForums.com.
pro-handyman
Evening,
I've got 30x30 ceramics to tile onto chipboard in bathroom roughly an area of 6'x4'
I know chipboard is not ideal in a bathroom however I'm happy that it's in good condition and solid on 8"x2" joists with little if any movement when i walk on it (I'm 16st btw!)
With this in mind I was going stick and screw 6mm Hardie board. Would Bal single part fastflex the right choice of product to stick board and tiles and Bal Supaflex to grout?
Thanks in advance
Andy Tiler
1,043
manchester
Evening,
Thanks in advance
hi pro handy man that is the best adhesive for the job imo fastflex is an s2 adhesive. but u need to double check the deflection one way to do this is to fill a glass with water put it in the middle of the room. walk around the glass it if it spills theres more than likely to be to much movement. b4 u tile screw down the exhisting chipboard to the joists then overboard with hardi screw down at 200mm centres u can use any powdered adhesive under the board but on top fastflex
would b my choice :thumbsup:hope this helps
Just noticed your signature mate:yikes:
Andy Carroll Tiling Limited, Manchester
Is that what you do in the close season:lol:
Reply to Chipboard, 6mm Hardie & Bal single part fastflex in the UK Tiling Forum area at TilersForums.com
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
Hi all, new to the forum, I'm a customer of a bodged tiling job done 2 years ago by a general...
Hi guys, Last time I posted here I was having a first attempt at tiling the walls in a shower...
Waluigi
Hi, I'm currently renovating and my next job is tiling. I have new T&G 22mm chipboard screwed...
2 3
15K
So after a couple of weeks trialing @ISOMAT UK products, thought it was time to give initial...
9K
