Guest viewing is limited
Discuss chipboard floor in the UK Tiling Forum area at TilersForums.com.
suave
quick one guys,started tearing up a bathroom floor for my dad yesterday,it was some sort of vinyl glued to 6mm ply which was also looked to be glued and screwed,total nitemare to get up,got the wc out,floor up back to the original chipboard which dosent look too good at some points,i was thinkin once ive flushed the chipboard off,cover with 6mm backerboard or 15mm ply,what would you guys suggest?
also iam going to give mapei products a go this time,what should i be goin for for this job?hope ive explained this ok,many thanks!
suave
forgot to say tiles are 330x330 glazed ceramic
suave
If the chipboard is solid - no deflection - then 6mm backerboard is the way to go, glued and screwed. If the chipboard is in any way suspect then you would be better to relace the whole lot with 18mm ply and tile onto that. backerboard on top of this too will be perfect. Use Mapei keraquick, and if going striaght onto the ply then use Latex Plus with it.
thanks GG not used rapid set before,got a wee bit of time on my side would keraflex be ok?
Reply to chipboard floor in the UK Tiling Forum area at TilersForums.com
I'm a total tiling beginner having my kitchen/diner redone by builders. The dining area has a...
chipboard floor
