SteUK
Hi all,
Tiling my bathroom and wonder if I might get a sanity check!?
Got all the tiles out last night to sort good from bad. They were a little dusty so used a sponge and a number of buckets of cold clean water to clean them. Left stacked up in 15's over night. Checked on how clean they were this morning and there is water weeping on the tops of tiles between stacked tiles. More so in the piles nearer the radiator (makes sense I guess). I dried all the tops and restacked. Checked them again just, after an hour, and there is returned moisture. I didn't drench them when cleaning them and, naturally, they feel bone dry to the touch.
Can I crack on with the tiling? Or should I wait till they have stopped giving up wate?
Tiles are 300mm x 200mm x 9mm glazed ceramic. Will be fixing with Mapei Keraflex s1 maxi (white). Tanked around shower-bath with mapegum. Substrate under that is tile backer board.
Thanks!
Ste
Thanks!
Ste
