Cleaning and sealing with Universeal .
Info here doug :
[h=4]Heavy Duty Cleaner[/h]Universeal Extreme Clean is a special cleaner that is nearly odourless and highly economic. Universeal Extreme Clean removes grease and oil, all kinds of ingrained dirt, stubborn stains as well as floor polish residues, old acrylic emulsions, care products, etc.
For thoroughly cleaning used or exceptionally dirty natural stone and tiled surfaces, suitable for use on polished, finely honed and rough marble and other natural stones and glazed surfaces. Suitable for internal and external use.[Data Sheet]
[h=4]Special Features[/h]
  • Highly effective, dissolves & removes ingrained dirt, wax films, grease & oil
  • Acid free formula
  • Suitable on ceramics & natural stone
  • Internal & external use
  • Safe & easy to use
[h=4]Packaging Options:[/h]
  • 1 Litre bottles with childproof cap (12 per carton)
[h=4]Coverage:[/h]Up to 25m2 per litre. Coverage will vary depending on the ratio of dilution.
[h=4]Directions for use:[/h]Apply an undiluted solution of Universeal Extreme Clean or diluted up to 1:5 depending on the nature of the soiled area. Allow the product to work for 10 to 20 minutes; brush occasionally. Do not allow to dry, Add warm water if necessary, brush areas that are most dirtied again before wiping up solution. On larger areas, use a squeegee and wet vacuum to remove the product, wash and rinse the area thoroughly with clean water. If the desired result has not been achieved first time, a second or third application may be necessary brushing the areas more vigorously. Please Note: avoid splashes on sensitive areas such as metal or wood, painted or varnished surfaces, wall paper, etc. Protective gloves must be worn at all times while using this product. We highly recommend trying the product in an inconspicuous area prior to use.
[h=4]Advice:[/h]For removing wax layers and the like, we recommend using Universeal Pro-Strip, for cement and grout residues use Universeal Grout Film Remover.
DHTiling,
DHTiling,
DHTiling,
DHTiling,
