L
Linear Tiler
Hi all. Looked at a job which is an integral double garage. My client has ordered 900 x 450 slate effect porcelain tiles in black. The floor area is just over 27sqm. The floor is concrete and in pretty good nick in terms of flatness and being level.
The reason I need a bit of advice is it will still be used as a garage and the tiles will have an M3 sat on them every night.
So...
Will the substrate need to be 100% (not just close to) flat and level?
Would an uncoupling membrane (such as Schluter ditra or ditra-XL) be needed?
Any ideas on edging to entrance of garage? (was thinking stainless steel sq edge?)
and just to check, as I don't normally have cars running over my installations, will a flex addy be good enough or do I need to be adding some sort of ad mix to give extra flex?
Help and advice much needed!
So...
