V
vapingvision
Hello guys,
I've bought a Dallmer vertical drain to fit a showerlay board. The drain has to fit into a 110mm waste pipe going out over the drain vertically. The board shall be cut so the dallmer does sit over the drain.
The vertical 110mm goes into a 110mm p trap so I don't actually need the trap of the dallmer.
My question is, does anyone know where I can get an O ring that has a 90mm ID, and a 110mm od to seal the Dallmer into the 110mm pipe?
Thank you in advance.
James
James
