Leaking showerlay
It's tiled. Grout has had a few days to dry. Used a Bal single part flexi and Ultra Flex Joint grout.
You can see the skirting isn't in yet but it's all tanked so should be waterproof (have only been aiming the showerhead at the centre anyway).
The top of the showerlay and marmox board elsewhere in the room wasn't tanked other than tape over the joints at the edges.
How is it sealed round the edge of the square plastic round the grille?
I believe the tiles are just seated into adhesive around the edge of the plastic - will have to check with the tiler. Does this normally need sealing? My understanding was that you could simply tile straight onto showerlay.
I think there is an issue with the tanking here
I checked all the tanking before the tiles went down - Schluter Kerdi matting applied to all walls with Kerdi Coll, then joints taped to showerlay with Kerdi tape, then reinforcemens glued in the corners. The only exception is the righthand wall where the tiler ran out of Kerdi matting so used a sheet of Homelux wall.
With all that said, whilst testing it I've been very careful not to get water beyond the centre of the floor so I don't think it's even getting close to the tanked parts.
How long had that sealant been left to go off befire running the water.
The bubblie type look to the Silicon in picture two suggest to me the Silicon has got wet before its cured, long before
Ok hold up... I've just found a piece of ply which looks like plumber has cut out today with a multimaster or similar. Looks like the builder did not cut out a recess for the horizontal pipe earlier. Whilst he hasn't visibly damaged the underside of the board I'm going to guess this probably wasn't good for the drain fitting?
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
