Discuss Leaking showerlay in the Australia Tiling Forum area at TilersForums.com.
I checked all the tanking before the tiles went down - Schluter Kerdi matting applied to all walls with Kerdi Coll, then joints taped to showerlay with Kerdi tape, then reinforcemens glued in the corners. The only exception is the righthand wall where the tiler ran out of Kerdi matting so used a sheet of Homelux wall.I think there is an issue with the tanking here
Ok hold up... I've just found a piece of ply which looks like plumber has cut out today with a multimaster or similar. Looks like the builder did not cut out a recess for the horizontal pipe earlier. Whilst he hasn't visibly damaged the underside of the board I'm going to guess this probably wasn't good for the drain fitting?
I wonder if the plumber's multimaster attack somehow delaminated the plastic upper from the metal lower and water is ingressing between the layers? I definitely didn't see any water leaking from the rubber seal.Could of held the trap at an angle causing water to pass the seal :-D
Reply to Leaking showerlay in the Australia Tiling Forum area at TilersForums.com
