completehandy
I’m planning to build a new raised deck / balcony on the back of my bungalow which is built on a sloping site. It will be around 2.4 metres out from the bungalow and probably 3.2 metres long.
The main issues are controlling costs as I’m very tight on budget, minimal on-going maintenance and ideally creating a dry area underneath to store the mower and other gardening tools. (It will be around 1.7 metres off the ground)
At the moment my plan is to create the main decking structure from timber supported at the front on brick columns and by a wall plate on the house side.
I don’t really want to use timber decking due to maintenance and the fact that it isn’t waterproof. Instead I’m considering using 18mm ply or OSB3 for the floor surface (possibly two layers) and laying a Ditra matting type product on top of this with porcelain tiles on that. I would presumably have to tape the joints in the matting and possibly add some uPVC angle or similar around the open sides to protect the edges of the ply / OSB from water ingress. Would the Ditra matting act as a waterproof layer or would I need to somehow waterproof the ply before it was laid. I know Schluter systems do some items especially for this type of application but believe they are very expensive.
What do you think? Any suggestions would be much appreciated.
John.
John.
