Discuss Correct Adhesive For Garage Floor Tiles in the Best Floor Tiles area at TilersForums.com.
DarkSource
I've had a bit of a think about this and I'm confident it's possible. There isn't essentially going to be any point loading as it'll be spread over a 600x600mm (0.36 m2) tile. Now, marmox say their boards can cope with 40 tonnes per m2 so with a tile + adhesive ontop you'd have to have an immense amount of weight to get any compression. Even a 3000kg van is only 750kg at each corner which is well within the capabilities of the products and each tyre has a contact patch of around 200x200mm so, not exactly a stiletto!
It is maybe worth doing a test beforehand but, a 20mm board, then an S1 adhesive (tilemaster setaflex) or if you really want the belt and braces approach an S2 (tilemaster ultimate), then a grade 4/5 porcelain tile, would be my choice.
Thanks Bri - that really helps. Will start insulation and drywall in a month or so, so tiling is still a little way off, which gives me time to experiment.
K
Kevbos
Make sure you flat the back of each tile also to fill any frogs. Or undulations in tile this'll help strengthen the tile and relate a solid bed
Lou
Admin
888
1,473
Staffordshire
Reply to Correct Adhesive For Garage Floor Tiles in the Best Floor Tiles area at TilersForums.com
I'm planning on tiling my porch, and the tiles and adhesive will take up around 13mm of height...
    • Friendly
I'm going to be installing Marmox multi boards, on two (internal walls) I'll use 4mm, just so I...
Hi all, I'm an enthusiastic DIY'er (first time poster) who has been slowly chipping away at an...
Best Floor Tiles
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 2 1.2%
    Votes: 5 3.1%
