Cost effective tile cutter for 600x300 pocelain floor tile cutter
If it's a one off job, and you have a grinder or can borrow one, get a decent blade for about 20 quid and Bob's your uncle..!
Thanks for that Andy,
I did try a small angle grinder with a 110mm marcrist diamond blade but it was a terrable cut.
Can you please recommend one i can give a try.
Turbo X Diamond Porcelain Blade
Home / Cutting / Turbo X Diamond Porcelain Blade
Turbo X designed Diamond Blade for angle grinders particularly for cutting hard material such as porcelain, hard ceramics and quartz. Only 1.2mm thick and with a 10mm high segment giving fast clean cutting and a long life. Available in 115mm and 125mm.
These are good blades from ATS diamond tools..
(Ignore this first link, my mistake)...🙂
Thanks Andy that looks just the job.
I have an old Ishii Big Clinker and to be honest it does the job. It looks like the Big clinker 2 from screwfix.
I will have a try with that and the angle grinder and see how I get on.
Thanks again
Col
Colo,
Colo,
Colo,
Colo,
