cracked tiles
Or they used wet ply that is drying out and shrinking
If the crack was caused by water ingress then it would buckle rather than split
Thanks guys! Any tips on what to look for when we remove the damaged tiles?
Is there anything i can do to minimise chance of repeat (which doesn't involve retiling the entire wall)?
Theres no easy answer for this, as diamond has said, the wall is getting moisture into it and it could be better to replace with the hardie backer.
Hi Hem
No easy way, what ever you do to resolve the problem is always likely to show as a patch. Probably best to remove and retile the whole wall. Could maybe try one of the mat systems which would act as a decoupling membrane too and absorb some of the movement
