cracking screeds/tiles and underfloor heating
Hi,
Have just encountered a problem with a row of cut Travatine marble tiles cracking at a door threshold.
The tiles are laid on an underfloor heating system, and the cracks have appeared along the threshold of a door that meets carpet on the other side.
Did you find that using a patch of Ditra as you described solved this problem? Or can anyone else recommend a fix to the problem?? That will not involve a huge amount of work.
thanks
Hi Johnny i have used about 4000 mts of PCI PECILASTIC in total yes have used it in these situations and had no problems yet pm me if you want any more info 😛ete
PCI Pecilastic®
Hi, to repair a cracks in screed, I normaly use a 2part epoxy resin with stainless steel pins. I would´nt use ditra as a "Plaster":8:2Balls
JOHNNYCLARKE,
Perry,
JOHNNYCLARKE,
Perry,
