J Sid
I'm going to be using the ultra rapid set S1 white adhesive now being sold at CTD.
can't find a data sheet for it, has anyone got a link to it ?
best I can find is the data sheet for the Proflex SP which says:
Underfloor Heating (UFH): If UFH is being installed it must be fully commissioned before starting the tiling process to ensure it is in full working
order. This includes both electric mat and water pipe systems. Once the UFH has been commissioned it can be set to a low level to provide a max floor temperature of 15˚C whilst the tiling and grouting processes are undertaken. It is critical that this temperature is not exceeded as this can force dry the adhesive and grout with the potential of causing cracks in the installation or tiles to de-bond. Maintain this temperature for a minimum period of 7 days while the installation cures and hardens. After this time the UFH can be brought up to the required room temperature slowly at a rate of 5˚C per day. Render: When tiling to new render it must be ensured that the render is a minimum of 4 weeks old and is thoroughly strong, dry, dust and efflorescence free and stable.
not come across this recommendation with my present adhesive.
the word CAN is very hard helpful.... It SHOULD or it SHOULDN'T would be more helpful
