ryanbrown
If the back of the tile is getting saturated i think that probally means too much water in the cutter. A thinnish stripe on the back shouuld be ok to work with straight away after drying with a rag. If more than - I wouuld say 25% - of the back of tile is getting soaked then you probally need less water in the cutter and also dry the surface of the cutter in between cuts so your not sliding it through water.
p.s have you taken the guide of the cutter?
