Guest viewing is limited
Tiling Tool Suppliers
Discuss Cutter for lots of work! in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
I've had a quote provisionally agreed to cut and supply a company with approx 1/2 million marble mosaic tiles all about 10mm x 10mm x 5mm thick.
Basically at the moment I'm running cut rods through a Plasplugs Contractor Plus (500 watt, 150mm disc) to get 5mm thick rods and then cutting these into individual pieces with a hammer and hardie.
The problem at the moment is that passing the rods through the saw is fairly slow so....
  • Should I get a more powerfull saw (bear in mind I need a saw that doesn't have a gap of more than 4mm between the blade and the top cover)
  • Or will the work be faster if I used more expensive diamond blades?
Cheers
Reply to Cutter for lots of work! in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
Hi guys, i took some jobs as a contractor for some MC Donald's restaurants but i find it quite...
My mum is having her bathroom fitted and she sent me some photos and my partner pointed out that...
5K
Hi Gents, I've got two cutters, a TS-40 and a TS-60, along with a wet saw. However I'm finding...
6K
Popular Tile Cutter Threads
Bury St Edmunds, United Kingdom
    Votes: 5 5.7%
    Votes: 6 6.9%
    Votes: 5 5.7%
    Votes: 22 25.3%
    Votes: 13 14.9%
    Votes: 27 31.0%
    Votes: 3 3.4%
    Votes: 2 2.3%
    Votes: 18 20.7%
    Votes: 14 16.1%
    Votes: 6 6.9%
    Votes: 5 5.7%
    Votes: 3 3.4%
