cutting a contour in a porcelain tile
bonemachine
what your best way of cutting a contour in a porcelain tiles 450x450. Im butting up to a pillar and need the neatest, almost perfect possible cut......any suggestions?
cut out the contour on a shape tracer, piece of paper or card,make sure it,s exact,then mark it on to the tile,you can cut it out in slithers then use your nippers to trim it of before filing back!
hope this helps
hope this helps
Same as david, when you cut your template make sure it is the same size as the tile. I use an angle grinder to remove all the waste and a diamond tile file to smooth the sharp edges.
Also another point be careful if using a pencil to mark porcelain as it can mark the tile and can be difficult to remove.
What is the pillar made of? wood, plaster? I'd be tempted to chisel a bit off the bottom (10mm deep) off the piller and slide the tile underneath, your cut can be a bit rougher then and would be quicker (well for me anyway) of course if it's a marble pillar it would be easier and quicker to shape the tile.
to cut the pillar flip the tile upside down and rest a saw flat on top then run the saw round the base. The thickness of the blade and maybe resting the tile on some spacers should allow enough room for the adhesive as well
Just another suggestion
For any circle cuts I use the shaw cutter, Dave at TT sells them
Brilliant, the little sucker grips well. When scored do some drop cuts and snap off with ceramic and porcelain, great little tool. Someone asked me how I made such a neat circle and they were well impressed with the opening for a toilet waste pipe.
bonemachine,
Deleted member 1779,
bonemachine,
