cornish_crofter
You won't be able to loosen off the elbow on the 32mm waste - it's solvent weld.
Either, remove the trap and try to feed the tile around the elbow,
Or, cut the pipe half way from the floor and rejoin after you've tiled using a solvent weld connector.
The other one, Dave's suggestion may work.
