Discuss Decoup mat in the Australia Tiling Forum area at TilersForums.com.
Mark@Tilemaster
NOT VALID
129
283
Leyland
This is a good question and one that i was asked for the first time last week, can the matting be used on walls? In all honesty i don't know the definitive answer because in theory it should work but as mentioned above the concern is weight pulling on the matting.
For now we would have to say no but we will begin some trials on this and we will inform you of the results once the tests have been completed.
In regards to fixing the Dural to these floorboards, it is worth checking out what type/brand of floorboards they are. Some floorboards are finished with a protective coating and this surface can be difficult to bond to. If there is no treatment on the surface, i suggest you follow Weber's instructions for priming given that you are using their SPF - best to follow their guidance.
Q
Qwerty
Might sound a stupid question but could this used on walls as it's so thin...as in if someone had blocked a door way up with out removing the wood frame.
I'm certain it can. I used some thicker Mapei Mapetex for this exact thing around 18 months ago and it worked a treat [emoji106]
Reply to Decoup mat in the Australia Tiling Forum area at TilersForums.com
Hi got a job to start prepping next week 60x60 porcelain going on 18ml ply with electric...
6K
SJPurdy
Hi all A customer has a 4m2 bathroom floor, which has floorboards down at the moment. They are...
21K
I
Rookery
Hi, Just venturing over from the plumbing forums. I'm after some advice about Ditra mat, I went...
13K
Seeing some of the recent comments about laying UFH onto ply flooring & use of decoup mats I...
6K
trevortine
macten
Nottingham
Decoup mat
    Votes: 9 5.7%
    Votes: 15 9.6%
    Votes: 11 7.0%
    Votes: 47 29.9%
    Votes: 19 12.1%
    Votes: 37 23.6%
    Votes: 4 2.5%
    Votes: 21 13.4%
    Votes: 18 11.5%
    Votes: 17 10.8%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.5%
