Deflection issue with No More Ply down
The bounce has definitely reduced with extra screws. I just used the No More Ply screws. I'm now thinking that maybe vinyl tiles is the only solution without ripping up the NMP and half of the floorboards they are now at one with.
TBH mate its difficult trying to make an assessment with out being there ...your dancing video help a bit and to me it looks like the nmp bouncing on the floor boards......personally I'm not a fan of nmp prefer hardie stuck down with a full bed of adhesive and screwed...
Choice is yours mate.....good luck.
Personally I have never used NMP as I put my faith in other products. Strengthen the floor as already stated if you can and it should help massively
Used NMP once, you need more glue than they advise...I'll stick with Hardie.
Yeah i am surprised. I think this has been the problem. I have now added screws and there is very little deflection as far as i can see.
Go for it then....I would recommend using bal single part fast flex and bal wide joint grout with GT1 admix and 10mm notch trowel and back skim the tiles.
BTW....don't blame me if it fails 🙄
Did a test area using bal single fast flex...its messy stuff and quite runny but so far so good.
I try not to blame anyone for anything, it rarely gets you very far. Unless its a question of losing things, and then it's always the Mrs hiding my stuff.
DIY Tiling Forum
Deleted member 46792,
Dan,
Dan,
