Discuss DeWalt DWC410 Hand Held Tile Saw NOW at Trade Tiler. in the UK Tiling Forum area at TilersForums.com.
DHTiling
TradeTiler.Ltd DeWalt Hand Held Tile Saw
Wet or dry portable tile cutting saw (really useful on large format tiles)
1300W motor delivers the power to cut through not omly tiles but granite, porcelain, concrete and stone materials
Lock-on button reduces fatigue during long cuts
Height adjustable shoe allows cuts between 0 - 34mm
Bevels to 45º for angled cuts
Easily accessible brushes for quick and easy servicing
Water line, with adjustable flow, feeds both sides of the blade decreasing dust also increasing blade performance and life
Includes a premium 110mm continuous rim diamond blade for a fine finish and minimal chipping in tiles and ceramics stone etc.
RCD circuit breaker fitted for user safety in wet cutting
-Specifications-
2m water feed tube with universal fitting
Blade diameter 110mm - 20mm bore (will acomodate 115mm blades)
Tradetiler includes 20-22.2 mm adapter ring to alow standard 22.2mm bore blade use
Max depth of cut at 90º = 34mm
Max depth of cut at 45º = 21mm
Bevel capacity 0 - 45º
Spindle speed 13,000 rpm
Power input 1300w
Blade change spanners included
Weight 3Kg
12 month warranty and 30 day 'no quibble' money back guarantee
stefanm
I have one of these, but called the Dw860 for South America, Asia and Africa, no RDC though, nice cutter, wasn't happy with the supplied blade, maybe a different blade for the market here, only tried it on a ceramic, along with 3 others to test performance, I ended up using a bosch blade, blades are very cheap here so testing 4-5 blades is not a problem. The cutter has a low vibration, which is very helpful, especially as 99% of cutters used over here (India) are of this type, I managed to even get a factory finish on my cuts. If your using this cutter on site you can hook it up to a submersible pump in a bucket if you have no water supply. I won't tell the price I paid for the cutter though!
Reply to DeWalt DWC410 Hand Held Tile Saw NOW at Trade Tiler. in the UK Tiling Forum area at TilersForums.com
Hi all, Don't know if this is a good saw but seems a very good price. Thought i's post it here...
9K
hi i am selling my Dewalt D24000 110v tile saw mark2 version for £500-00p it was bought from...
8K
Aston
hi people.i have just ordered a DeWalt DWC410 240 Volt Hand Held Wet Circular Tile Sawhas anyone...
12K
Dan s
Hi, First time posting. Looking for local tiler for the following project. Retail fit out...
JG Shopfitting
Makita BSR730 Circular saw 24 v ( Bare No battery but with case) Bought new 3 years ago and...
5K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
