Discuss Diamond set in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
I know some of you know of them great SIGMA cutters,lol.
well they also like the montys have a rule with two sets of measurements on it,one for 90 degrees and the other for 45,easy done,if wall off adjust accordingly,
YES..but how do you take the measurement and transfer to the tile...:dizzy2:
H
hillhead
i dont see the point in setting your cutter to a 45 degree angle,ya might as well mark ya tile,set the tile in ya cutter line up with scoring wheel,cut and snap,job done,cos if that wall is out,its gonna keep running out,so why waste time with the 45?
Jimmy
ok,everyone does it different.Most times i do it its in a new house therefore the skirting aint on yet as i request,that means that i usually have 19mm to play with,the reason for the 45 is for speed of cuts,if wall is out i can adjust the cutter away fron the 45 slightly which will work fine,i normally leave about 5-10mm under a 19mm skirting board.
brian c
ok lads,now be gentle..
first of all for demo purposes we are using a 100mmX100mm tile.
we are going to use a template here,so take the measurements diagonally across the tile and we get 140mm so we now have a template 100x140.
we now put a tile on top of the first field tile which is not touching the wall and place a full tile on top of this.Now place the 100 side of template against the wall and pull back to create a small gap the same size as the spacer,now draw a line across the tile with the other 100 end of the template.Cut tile to suit and fix.
I hope you can understand this ,sounds complicated but its a doddle and save sloads of time on large floor jobs.
I told you Dave would know.
Do any of you know of this technique or use it?
If the wall is out ,you still will have an excellent cut tile to follow the wall.
medlar
Seems a bit overboard to me Brian mate,means ya messing on with paper first then ya tile then cutting.
Jimmy
medlar
for straight walls and without skirting yes that would be quick,but for walls that are not straight and do have skirting,its quicker to measure and cut.But as you say we all have our own little ways of doing things.
Jimmy
brian c
jimmy itys a doddle m8,dont knock it..give it a go and see the time you save buty as i said its probably a better technique on Large m2 jobs and not the normal toilet floors at 4m2 or whatever.
Go try it out with some 100x100 tiles in the kitchen and see what i mean,it will take 10 mins or so m8...try it.
picture1689-polished-porc.html"]
[/URL]
I must point out this was marks job and i was giving him a hand on it,but just as you asked for some pics.
grumpygrouter
Jimmy
Te best reason for setting the angle Jimmy is if you are doing repetative cuts and you are working to a rectangle or square inside a border or something like that where you know the angles are a proper 90deg. Obviously with walls that is not always the case, neither are the always straight. if the walls are straight but run out say by 2 or 3 deg (for instance) you could mark your first tile as you would normaly, set the angle on the cutter for the first tile and then lock it into position for the rest of the cuts.
grumpygrouter
Agree Grumps,providing you are working to a square yes,i have seen many rooms over the last 30 years run out by approx 1 1/2" and thats a lot
Jimmy
I agree jimmy, check out my granite floor in my album. If you look closely you will see along the bottom right of the picture that I had to cut ever larger slivers to accommodate the the wall run out....and before anybody dives in, yes I know that you can adjust to get rid of slivers but if they weren't in that position, they would have been somewhere else in the room.
My client wanted the best "impression" from the doorway that you can see as that would be the most "used" access. The cuts at that end of the room were balanced and the slivers were to be covered by a cabinet of some sort.:yes:
Reply to Diamond set in the British & UK Tiling Forum area at TilersForums.com
Hello everyone, I have redone the tiles (porcelain ones) in the kitchen. The grout used, BAL...
Hello you Pro’s out there. I am embarking on replacing my current outdoor patio concrete slabs...
  • Sticky
Diamond set
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
