Discuss Ditra laying methods in the UK Tiling Forum area at TilersForums.com.
Peter
Peter
Bit optimistic with price I thought. Got all the bits to make it for about £3 from the local builders merchants. Thick brush shaft, shaft clip and brackets. Just unsure what to use for the actual roller itself. Any ideas? Brush shaft cut off or rolling pin perhaps.
Failing that, might have to give Karl Dahm a weeks wages for one. :lol:
Peter
Would be interested to know the coverage difference. Not entirely convinced that Ditra rubbed down by hand gives as good coverage as it would do if it's rolled and the adhesive is squashed more, even when mixed a bit looser. Ever notice there are some patches lighter than others? One for the testing team perhaps?
Dougs Third Go
whats wrong with just dry troweling over the top with a plasterers trowel and body pressure ??
only being a featherweight that's why I use a length of batten Dave, seem to be able to get more pressure onto mat without skidding but still be able to move it along:thumbsup:
jonnyc
Well this brings another question up. I have always covered the top of mat with adhesive at same time as fixing mat.the reason for this is two fold.one is that when you quote the amount of adhesive you will need to fix tiles it is based on a flat subfloor not a ribbed surface that needs to be filled in . The other is the extra time needed to fill in the voids. When you fix a lot of metres in a year bothnthesevfactors make a big difference
John Benton
1,138
Leeds
That's very true Jonny, you're effectively putting a solid bed of approx 3-4mm when you take into account the addy under the mat and then filling the depth of the voids on top, before you've even put your addy on to fix tiles. Like you say, doing it on a regular basis uses up hell of a lot of addy, and someone has to pay for it :thumbsup:
Reply to Ditra laying methods in the UK Tiling Forum area at TilersForums.com
K
Good Evening All I have always used my plastering trowel when pressing the Ditra into the...
13K
kaharrison9
K
K
Evening All. Couple of photos as know there appreciated. Looked at different rollers in the UK...
7K
11K
Rizzle from the Portizzle
http://www.*************************.com/water-underfloor-heating-152-w.asp Supplying Water...
9K
we have 80 m floor to tile which has been layed for 4 weeks now and it is a gyvlon screed type...
11K
Mark S
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
