Discuss Ditra on Anhydrite in the Canada Tile Advice area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Will never happen .. they are all frightened to commit.
the issue is that as we (the binder suppliers) do not make the adhesives so we have no control and cannot take responsibility for how their gear is tested or how it performs. The best we can do is test the adhesives ourselves which has often been done. we are forced by the contracts and legislation that bind us to make relatively vague and wooly comments. i have advocated the use of gypsum adhesives for quite some time and am aware of very few failures where they have been used.
It is also unreasonable to say a cement adhesive wont work because here are lots of cases when it works fine. The majority of issues come when a tiler or a builder miss out a crucial bit e.g missing out joints, forgetting to moisture test, ignoring dust and dirt on the screed, failing to prep or a combination of all.
Mark S
Everyone knows the correct prep for Anydrite screeds by now hopefully, sand and prime if using cement based flexible adhesives, sand and Kerakoll H40 Ideal, or the Creative Impressions version GBTA, I believe Kerakoll do a de-coupling nat so maybe worth contacting them.
I always think its best to try where possible to stick to 1 manufacturer
Mark S, Technical and Specification Manager, Gyvlon Ltd
Gazzer
But Mark this is about what adhesive to use to stick the Ditra to an Anhydrite screed. Do any of those adhesive stick the Ditra?
DHTiling
That is the same for gypsum adhesives as well though..
Yes gypsum to gypsum is the more attractive route but adhesive comps are ripping the industry off with the prices they are charging.. material costs are no more for gypsum or cement IMO.. so why do they rip us off.?
Dougs Third Go
because (imo) if we don't pay, we get no comeback:incazzato:
Ajax123
1,213
Lincolnshire
if you make the screed why dont you make a tile adhesive for it as well ?
Thats my point Gary we don't make the screed. We just make the binder which is the "cement" bit. We (Francis flower) do supply quite a number of adhesive manufacturers as well though.
Ajax123
1,213
Lincolnshire
would that it were true Mark that everyone knows the correct prep. I think it's fair to say most reputable and responsible tilers take the trouble to research it. The problem is not always the tilers though. There is some merit in the suggestion of using a pressure sensitive adhesive similar to those used for vinyl but I don't know of any specific research done by any of the adhesive manufacturers to ratify this.
Ajax123
1,213
Lincolnshire
i have seen both used successfully although it is fair to say I have seen a few issues where the h40ideal has been used to stick ditra to a primed screed... David Howe was one such case.
Gazzer
is there a rapid set gypsum adhesive?, I've always used rapid set for ditra/uncouplers just for the reason that if you need to pull a tile your're not going to pull the mat up too. I remember Dave having issues with, I think, kerakoll addy and uncoupling mat.
Gypfix is 3 -4 hours
Reply to Ditra on Anhydrite in the Canada Tile Advice area at TilersForums.com
Hi guys, 1st post so apologies if I’ve missed any key info. We’ve had liquid screed laid 2...
Hi all, Was looking for some advice in regards to micro-cracks appearing on the SLC on top of...
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Ditra on Anhydrite
    Votes: 9 5.4%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 47 28.0%
    Votes: 21 12.5%
    Votes: 40 23.8%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.7%
    Votes: 19 11.3%
    Votes: 17 10.1%
    Votes: 8 4.8%
    Votes: 5 3.0%
