Discuss Ditra on Anhydrite in the Canada Tile Advice area at TilersForums.com.
Al@Lifetiles
What has this to do with Anhydrite screeds? Surely that would have been the same with cement screed with stone. Its the stone that caused the problem ....?
Obviously didn't make my point clear.
The bond between ditra and screed was perfect.
I only mentioned the stone as that was why I had to lift ditra.
I am not familiar with Epoxy primers or gypsum based adhesives so my only question, given the result I had with cement based products, is why do I need them?
I'm totally open to new products and find it all very interesting but I do wonder if things can be over thought some times.
I hope my point is clear
Just a little bit more info on the TileMaster Anhyfix adhesive that is now out
Broken Link Removed
Also a useful Anhyfix Technical Guide
[DLMURL]http://www.tiletown.co.uk/published/39/resources/documents/TileMaster%20Anhyfix%20Technical%20Guide.pdf[/DLMURL]
beanz
Berkshire
I would go down the root of getting the adhesive company to do a spesification and let them do any tests that need doing I would not stick your neck out to far with these screeds.
Will they do a moisture test?
I finally had a look at this floor, and got some more details on it...
There is UFH, and it will be commisioned shortly.
There is celotex all around the perimeter of the floor. Is this usual!?! How do i deal with it (ie. stick the Ditra to it!?!)?
Customer has bought an Epoxy Primer (meant to make a note of brand, but as usual... Forgot), and Weber SPF.
Any thoughts? ;)
Ajax123
1,213
Lincolnshire
Any thoughts? ;)
Celotex round the edge is to prevent cold bridging. It should normally be covered by the skirtings and plasterboard. It is normally only 25mm thick.
beanz
Berkshire
The customer was a little too involved with this one, and he went 40mm!?! Not only that, but he got a little carried away, and did internal walls too... :-/
Ajax123
1,213
Lincolnshire
.oh dear. Not sure how to get round that....
beanz
Berkshire
Me neither!?! Only thing I can come up with is to use Tec 7, to stick the mat to the foam, but no idea what sort of bond it'll give!?! :-/
The screed itself looks like it'll be a pleasure to tile, as it's really flat. Nothing's ever straight forward though is it? Lol
Ajax123
1,213
Lincolnshire
What about if you we're to scrape out some of the foam down to say 10mm and fill it up with levelling compound or adhesive.
Just make sure theprepos done correctly and make sure when you mix the epoxy primer you use a spatula to scrape out all of part a into part be to mix it. Is it a water dispersable primer. They can soften be diluted to make them easier to penetrate the screed surface.
Reply to Ditra on Anhydrite in the Canada Tile Advice area at TilersForums.com
Hi guys, 1st post so apologies if I’ve missed any key info. We’ve had liquid screed laid 2...
Hi all, Was looking for some advice in regards to micro-cracks appearing on the SLC on top of...
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Ditra on Anhydrite
    Votes: 9 5.4%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 47 28.0%
    Votes: 21 12.5%
    Votes: 40 23.8%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.7%
    Votes: 19 11.3%
    Votes: 17 10.1%
    Votes: 8 4.8%
    Votes: 5 3.0%
