Guest viewing is limited
Dittra mat not sticking down
Ok Marios,
I've been using AF 200 for years and never had any issues with either wooden or concrete floors.
Water ingress will affect anything on floor or walls and if you so concerned about leaksor moisture, there is the only one solution which is complete floor waterproofing like wetroom or swimming pool but at its own expense.
Good luck...
Yes you are right, af200 sticks down good and it is recommended.
But what is winding me up at the moment is that Schluter recommend and show a cement based adhesive in their specification sheet, and I cannot, nor can anyone else based on the replies, get it to stick to the fleece.
Thanks for all your replies
It seems that no one can confirm sticking Dittra down with a cement based adhesive and confirm that it has stuck it is just loose laid/bedded
marios,
Gary Parshley,
marios,
Gary Parshley,
