Do you butter back of tiles
I'm with enduro, as long as I have a good solid substrate (I wouldn't tile it if it wasn't lol!) large format tiles.I'd up my trowel to an 8 or 10 and also give back of tiles a skim esp if they have a profiled back:santa_cheesy:
I generally use a floor trowel for large format wall tiles (aswell as floor) and back butter also. Always back butter when I need to be certain I've got 100% coverage i.e. heated floors.
You'd be amazed how many people simply push the tile onto the adhesive/wall rather than bedding it in properly.
Here's a piccie of a 600x300 porcelain fixed using tubbed gear and a 3mm plastic spreader which came in the adhesive - you know the type!
The tiles started to fall off the (freshly plastered) walls after 2 weeks.
Look at the coverage and be amazed!:santa_cheesy:
As others have said, use the right trowel for the tile and condition of the substrate then check coverage and backbutter if required but rarely have to.
can't see the problem myself...lol, how do people manage to get away with it..
robbbin,
Diamond Pool Finishers,
robbbin,
