GoneGuy
I always back butter any tile bigger than metros, with troweling both the substrate and tile I trowel both in same direction to prevent any air getting trapped
Totally agree with local. Not the best advice.Some tiles need skimming to fill holes or pits. Like tumbled marble.
Most tiles don't required back buttering if the substrate is flat and has been prepped well.
You might need to back butter corners of tiles that change thicknesses like slate etc. You start tiling with the thickest of the lot, and in the lowest corner of the floor then.
Nearly all tiles don't require applying adhesive to the floor and the tile.
And pretty much all wall tiles don't require it. Unless the wall is rough in an area or something.
Got a picture of what you want to tile?
